- Mar 26, 2017
- 12
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
The original pump for our pool rusted out. I am looking for advice on what to replace it with--should I go withe same pump or something different?
The pool is 13,500 gallon above ground using salt. The salt cell was replaced last year. The sand was washed two years ago. This site was very helpful with getting the pool in better shape than ever, which is why I am coming back to you folks for advice on the pump and two other issues:
--the sand works good, but I always use DE once or twice a week to clean the water a bit more. Would another filter media do a better job?
I am going to have to remove the sand filter to bolt down the new pump anyway, so now would be as good of time as any to change media.
--I would like suggestions on plumbing changes. I would like some valves to isolate the pump and/or filter for service and cleaning.
Our neighbor's new pool is hard-piped but would it be better to use flexible PVC or something and add valves?
--Moving the pump.
Ours is right next to the pool...maybe 18" to the edge of the stand. I am considering moving it back a couple of feet and also raising it up 1'-2'. Any thoughts on that?
--Moving the pump.
