Hello,
I have been experiencing an issue with my cleaner not working for the past month. I noticed that the pool is getting dirty so realized
one day that they pool cleaner does not move. I had my home warranty company look at it as I thought the cleaner pump was losing
pressure. The guy said that pressure was fine and my gears were probably stripped.
Ok, took cleaner apart and nothing, gears are not stripped and everything looks good. Tried cleaner again and it just does not move,
or occasionally will move very slow then stop cause cannot climb wall.
Here is what I noticed when my cleaner pump now comes on:
During normal operation, my pool pump will provide overflow from our spa to the pool as a waterfall feature, this has always been the case since
beginning. Also during normal operation, pool pump will shoot water out of bubbler on tanning shelf about 6-7".
**When the cleaner pump turns on, I noticed that the bubbler only comes out the water about 1-2", not like in normal use. Also, after
about 1 minute, the water will no longer spill out of the spa to the pool so no more water feature.
Obviously, the cleaner pump coming on is causing less pressure to the pool pump but I have no idea why? Before I call a tech company, hoping
the forum can provide some advice and maybe a fix that I can do or try first.
Shawn
Shawn
