I'm not able to get an easytouch panel to recognize an intelliflo pump. I've had the pump for 3 years and the pool installers just put in the easy touch panel. They could not get the panel to recognize the pump. I had the installers call pentair and pentair thought I needed to replace the drive on the pump.... Crazy since the pump and keypad work fine on the pump and everything else is new. I've done some troubleshooting and I am a former GC, so I understand the circuit, programming etc...
- I checked the cable going from J20 to pump. The cable continuity was fine. Pin receptacles seemed tight
- I checked the pins on the pump. Looked fine and cleaned them
- I disconnected the screen logic wires from J20 so only the pump was connected to isolate any issues. Still no comm
- I've set the pump as VS and tried resetting many times
- Panel menu for status always reads Normal initially after selecting VS than I go back to the main menu and then return to the inelliflo settings and it says NO COMM
- also after I set the circuit to pool, it always goes back to None and No comm after I return to the setting
- The pump display has never read no display
Has anybody ever heard of the drive being the issue for no comm? It's an expensive fix.
Thanks.
Thanks.
