Following the water balance and bromine set up instructions in the stickys, I kicked off my first spa in mid September.
The first month was great however when the floater ran low on bromine everything has gone a little wack.
The spa is a 6 person set up with waterfall and ozone. 350 gallons.
Here's what I mean.
Issue 1)
According to my Taylor test kit water balance wheel thingy:
a 50 TA with
200 CH and
any PH in normal range is out of balance at 100 degree water.
However my ph stayed steady in the 50-60 TA range. I did not allow it below 50, but when it's above 60 I get pH drift up and have to add muriatic acid.
Should I still leave the TA at 50-60 even though the Taylor water balance wheel thingy says I'm out of balance?
Issue 2)
Bromine floater. First couple weeks I had it cranked open to 8/10 and supplemented with bleach while bromine dissolved. At one point during the end of this period my chlorine measurements drifted up to 15+! When the drift up started I stopped adding chlorine and let the levels fall. Assuming the bromine kicked in and could let that work.
How do I properly calculate bromine levels with my kit?
Can the kit distinguish between bromine and chlorine levels?
Issue 3)
When the bromine drifted back down to a decent level I refilled the floater full, but closed her down to a 4/10. Levels fell to 0.8.
And then measured my CC, which was high so I started to SLAM to lower CC. I've been in SLAM protocol for 2 weeks, however I'm not measuring twice daily, only about 24 hours or so as time allows.
My last chlorine addition was 36hrs ago roughly and I SLAM to 15 instead of 10 because the CC won't go away!
I also open the floater back up to 6/10.
What's going on here?
Why won't CC lower?
Why isn't bromine kicking in so I can stop adding so much bleach?
Pool math logs from beginning of SLAM:
Here's what I mean.
Issue 1)
a 50 TA with
200 CH and
Issue 2)
Issue 3)
Why won't CC lower?
