Hi all, Hoping someone here can provide guidance. I had a 17,500 gallon pool built early this year and I noticed early on that the water level wasn't quite even on the tile line from one end of the pool to the other. It was close though and I disregarded. Now though the situation seems to have gotten worse and it is a few inches off- on one end the water is at the very top of the tile and the other end (right at a skimmer unfortunately) is the low point where it is at best halfway down the tile (about a 2 and 1/4" difference). It seems like a small amount over the span of the 34' of pool but I am afraid it may continue to oget worse and it also makes maintining the pool level a biut more challenging during the summer when it evaporates quickly. If I fill the pool any higher than halfway up the tile I cause a algae problem on the other side where there is a stone wall.
So any advice here? Is this a problem the builder should fix or am I on my on? I have left a couple messages with the builder but so far they wont return a call.
Appreciate any advice.
