I have a spa with a Minimax operator B224055MR76A. The board was burnt through at Relay K6. I believe this relay runs the number 1 motor. A 4 hp A.O. Smith turning a Waterway pump. This motor is 220 volts 7-187563-02 and is rated at 4.4/12 amps. I pulled the motor plug and figured out what color is corresponding to what prong.White (nuetral) to black reads 2.0 ohms,white to red reads 5 ohms,black to red reads 6.4 ohms. Does anyone know if these readings are within normal parameters or due I not dare to hook it up to the new board?
