Sounds like you might be getting a quote from Anthony & Sylvan. The quote from the A&S salesman said no Saltwater due to issues in Arizona or someplace with cement. He said that he would put one in for me for $1600 but couldnt recommend it.
Also my brother has a chlorinated pool not a SWG and he pays $50 a month approx in chemicals. What is the cost for SWGs monthly I get the initial price on salt water systems are around $1500 more but if chlorine chemicals are $50 a month that’s $600 per year just trying to do some math here. Is it just salt bags needed for SWG?
going with a 16x32 gunite with SWG - which SWG should i go with?
Need more information- gallon size for example. What shape is this pool and what are the depths? If you look at the PoolMath app at the top of the page ... go down to the bottom and look for "Calculating Pool Size". Try using that and letting us know how much you guess-timated it at. We'll offer better suggestions knowing this.
Maddie
Adding a spillover spa to my build would have added @ $8k. They are nice but for the small(ish) pool you listed I would not do it.
Have you read Pool School yet? You keep asking/mentioning "chemicals" for non-saltwater pools. Pool School will answer your questions regarding this. But in a nutshell, the only chemicals you add on a regular basis to any pool is chlorine and muriatic acid. Chlorine if no swg daily, muriatic acid usually weekly. Bleach is usually in the form of regular old household bleach. If you go saltwater, the pool will make its own chlorine so you will have nothing to add outside of the initial balancing and acid.
My 7 foot diameter attached spa and spillover into the pool added $8k to my contract price
Using Pool Math I got 20,500 gallons for 6 foot deep
Just curious why does the size matter? How much are gunite pools on average going up a size from 16x32? Is next size 18x36?
Did you do the spa? Any regrets
Maddie,
Another question is a 1 HP pump effective enough to run 20,000 gallon pool? Two pool builders are trying to talk me into UV but the cost to go to SWG is only $800 more and that is what I'm locked into right now.....
