Thread: vinyl liner replacement
    Aug 2007
    long island, ny
    14
    hi all,
    i'm in the middle of vinyl liner replacement. the plastic extrussion bottom lip cracked off on some spots. what is the best way to further secure the liner in place, in those spots. would silicon caulking help prevent liner movement? also mechanic told me there is a slow water leak at the skimmer piping,based on pressure test. however, the water level (old liner) dropped at the top of the light fixture, but he said the light niche is not leaking. could this be possible?
    thanks in advance,
    victor
    Brian
    18' round x 52" vinyl AGP holding aprox. 7633 gallons of crystal clear sparkling water, most of the time. Hayward 180 sand filter, 1 hp pump and 2-2x20 Fafco panels is parallel.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: vinyl liner replacement
    Quote Originally Posted by binrocha
    hi all,
    thanks in advance,
    victor
    Sorry, don't know how to advise you regarding repair of your liner; just posting so those who do will see this and can respond...
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    South Central NJ
    3,192
    We need a photo of the liner track where it's broken.
    WRT to the water level, it's possible there was more than one leak. Light niches can leak in several common areas. They can leak at the niche gasket, the conduit to the deck box, the niche itself,or a hole in the liner.
    A close physical inspection of the niche is called for. If there has been any ground shift or heavy equipment or steel conduit to the deck box, a test pull of the fixture's cord may be in order. If the conduit is metal, it may have sprung a leak. If the cord moves relatively easily, try "sealing" the cord's entry point in the niche with butyl tape.
    Scott
    PoolGuyNJ
    Owner of - PoolGuyNJ LLC
    Mar 2007
    Coastalish 'down easter'
    4,160
    Pretty much DITTO what Scott said (pics would really help!)
    If the missing pieces of track are small, I'd think that linerlock, extending ~1" on both sides might do the trick.
    Luv& Luk
    -Ted
    X-PertPool's Avatar
    Exeter, PA
    1,385
    liner lock both sides of the problem area and silicone can be used to fill in any gaps. Upon replacing the liner I would recommend installing aluminum liner track and it will never become brittle like plastic and break again.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
