This morning I noticed that my control box was flashing a "low flow". It was not a consistent flash, flashing perhaps 10 times or so, then a pause, then flashing 10 times or so again. Continued to do this.
I powered off the salt system and then turned it back on. The "low flow" was no longer flashing. All readings looked fine. I then reversed polarity and had significantly different readings for the Instant Salinity. The Voltage and Current readings were also different. Here's the readings:
I have tested salt level in my water using K1766. I got 3200. So Polarity 1 looks to be right on target.
Does this sound like a failing cell? Cell has been installed for 2 years.
Polarity 1
Voltage: 26.6 / Current 4.44 / Instant Salinity: -3100
Polarity 2
Voltage: 27.1 / Current 3.66 / Instant Salinity: -2400
Polarity 2
