Hello all!
First time poster here.
I would greatly appreciate a little help, if someone would not mind.
I recently purchased a house that came with an older hot tub. Everything seemed to be working on the tub so I drained it/filled it and then got the water in balance (bromine); all button functions, the timed cycles, the heater, and the freeze protection.
However, the jets will no longer disengage.
I tried using a different button/air hose that works, but that still did not work to turn off the jets.
The booster, light, and blower features all function correctly.
The relay clicks when I push the button (I'm not mistaken the small click from the air button)
I'm using the GFCI switch to control the on/off function.
The model of equipment is an Acura Systems Power Quip: DT50 DP45
I was going to try to switch the pump1/pump2 relay's (where the air hoses initially connect to from the top panel).
Any other suggestions perhaps?
TIA!
TIA!
