I bought the house in October of 2017 and the previous owner said that the pool was originally a salt water pool but had switched over to Chlorine, and it is still currently Chlorine.
I see that there is a old Jandy Aqua Pure 1400 on the pump system that I am sure is probably outdated or no longer functioning. However, it looks like the water has to pass through it on its way back to the pool.
1. If the pool is a chlorine pool does the SWG still work, would it still do anything?
2. If it is outdated/broken/ and water is still passing through it on its way back into the pool is that good/bad/does not matter?
Any other information that you can provide about the SWG would be most helpful. Thanks in advance.
