Results 1 to 7 of 7
Thread: Timing for resurfacing WWYD
    Aug 2009
    SF Bay Area (Lamorinda), CA
    122
    So we've resigned ourselves to the fact that our 17K gallon 1960's-era rectangular IG pool (concrete/plaster that had been fiberglassed by a previous owner) is going to have to be resurfaced. But now that the rainy season will be underway soon (we've had two pretty good but short rainstorms so far), and the pool is at the low point of our property (and we have heavy clay soil that stays heavy and soggy out into June), we're worried about the pool 'popping' while it's in its drained state during the resurfacing
    Which scenario sounds least likely to be problematic:
    1. Go for the resurfacing now and hope that the really heavy rains don't get going for another month or two
    2. Wait until spring when the rains have stopped but the ground is still pretty heavy and soggy
    3. Wait until late spring/early summer when the ground is dry but: 1. the water costs would be higher b/c of drought pricing (and we need to use the bulk of our water allocation for keeping the landscaping alive); 2. the pool would be out of commission during time we'd like to be using it
    thanks for your input
    1950's-era 17K gallon formerly fiberglass, newly replastered IG rectangle (~15x30'),
    Hayward S244S Sand Filter with Franklin Electric 0.75 HP motor and WhisperFlo WFE-3 pump
    Clear ThermaTex bubble cover
    Manual vacuum
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Timing for resurfacing WWYD
    What? 3 inches [from last week's No. Calif. storm] not enough for you?
    Seriously though, what kind of material will you use to resurface the pool shell? It sounds like you're leaning toward doing it sooner rather than later. I don't think Lafayette/Moraga/Orinda should get freezing temperatures for a while yet...
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Aug 2009
    122
    Quote Originally Posted by polyvue
    We're planning on having the fiberglass removed and converting it back to plaster.
    So is it the freezing/expansion that does the most pool-moving damage, more than just the weight/pressure of heavy wet clay soil and gravity?
    Manual vacuum
    polyvue's Avatar
    Aug 2009
    1,215
    Quote Originally Posted by PoolCleanerMom
    I must defer to those more versed in pool construction to provide a technical answer to your question, but my belief is that in the East Bay the water table and expansive soil could have a more immediate detrimental impact on the shell than freezing temperatures. Therefore, I think you're right to be concerned if replastering means emptying your pool for many weeks during a rainy period when the water table is elevated and soil conditions might lead to expansion.
    Very cold temperatures might affect the plaster setup, but this is only my conjecture.
    __
    South Central NJ
    3,192
    IF you have a drywell, do it when you want. If not, wait till you can be certain that the water table has dropped so the risk of the movement is minimized.
    Scott
    PoolGuyNJ
    Owner of - PoolGuyNJ LLC
    Aug 2009
    122
    Quote Originally Posted by PoolGuyNJ
    Scott
    PoolGuyNJ
    Sorry to be a bit clueless here - could you please explain what a "drywell" is? Thanks!
    Manual vacuum
    South Central NJ
    3,192
    Its a well point set in a gravel bed under the deep end attached to a pipe to the surface. A pool pump is attached when needed to suck any water from under the pool. It prevents hydrostatic pressure related problems like pop ups and such .
    When needed is defined here as anytime you need to empty the pool, such as when performing new coping, tile and or plastering or when installing a new liner or when working on a fiberglass pool.
    Scott
    PoolGuyNJ
