Thread: AutoPilot SC-48 Reading "Low Amps"
    I've cleaned the cell, inspected the wires and the pool chemistry is good. However, I'm now getting a "Low amps" reading and the amps are now .6 Voltage is fine at 28V. If the cell looks clean, but the amps are .6 does this mean the cell has died? Also starting to get algae because the chlorine level has dropped.
    Please help.
    weekend warrior
    10m*5m*1.6m =75,000 litre, Concrete pool resurfaced in 2007 with Quartzon plaster,outdoor inground pool, sand filter, non-swg.Pacific Islands.Water source is rain collected in mountain reservoir-No chemicals added at source. Double filtered and double UV treated before entering pool. Ph of water source = 7.4 to 7.6. Water not hard in calcium or iron or magnesium.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: AutoPilot SC-48 Reading "Low Amps"
    Quote Originally Posted by weekendwarrior
    Welcome to the forum, weekend warrior
    The Autopilot folks will address your question, but meanwhile I would urge you to not delay in fighting the algae -- use liquid chlorine. Please read up on how to do this in this article.
    Good luck to you!
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Sep 2009
    P. Pines, Florida
    29
    Not sure if it was a low voltage or amp but I think I had a similar issue a long time ago and it turned out to be the cell cable the part that attaches to the main panel and not the cell. Apparently I rolled the excess cable and let it dangle and the weight pulled the attachment and with time it was not making contact. They sent me a new cable and that was the end of it. From there on I would roll it and just let it rest on the piping w/out any wait pulling from the connectors.
    How old is the cell. If its 3yrs or more then its likely the cell going bad.
    Aqua-rite Aqr-x296 T3 15k
    Autopilot Dig-220/Sc-36(replaced)
    Inground pool 8.5k gallons
    Diamond Brite,built 2003
    DE filter
    Ft Lauderdale, Florida
    1,455
    Hi Weekendwarrior,
    Remove the cell and inspect the two outer blades and compare if these are shorter than the blades between them. This, along with the amp and volt results, would verify if the cell needs to be replaced.
    Also, as suggested, check your cell cord at both ends for damage or discoloration.
    Hope this helps.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Yamilrx, This was exactly the problem. The cell cord connector (male end of the cell cord) appeared to be fine when in fact the wire had pulled away and a connection to the AutoPilot box was no longer being made. The plastic around the wire made it look as though the cord was fine and a proper connection was made.
    Thank you for your help. Greatly appreciated in a time of need.
