My cell is 4 or 5 years old. This season, everything started out fine - SWG read 3200 and happily chugged along. Over the last couple weeks it started reducing the salt reading until the low salt light started flashing, then came on full.
in terms of salt, I tried to satisfy it by adding another bag. Test strips (about 5 of them) all say the salt level is around 3500 and the fact that I can faintly taste it supports that. So it’s not actually a salt too low issue.
ive tried recalibrating it- but the instantaneous reading starts at about 2500 or lower and ticks down from there. Last night I took the cell out and inspected it- there was a small amount of scale on it but generally clean. Nonetheless I did an acid cleaning on it, and it bubbles away for 5 mins or so and stopped. When I poured out the acid it was faintly black tinged- not sure if that’s normal as I haven’t personally cleaned it before.
Anyway, rinsed it off and threw the cell back in, salt reading is still coming in below 2200 and the cell won’t generate, so I threw liquid chlorine in until I can sort it out.
As a new cell will cost me $650ish, I want to be sure the old one is truly done first. When they reach the end of their life is it normal for them to just go from working to not over a week or two? Or is it normally a long slow degradation? Could this be another issue? Any other suggestions?
thanks!
thanks!
