We have lived in AZ for three years now, our pool is three years old. I've been following TFP from the beginning, fully embracing their methods We have an in-floor cleaning system, and it works great during the fall, winter, and spring months. I brush the walls and floor once a week during those months, and rarely see visible dirt at the bottom. But during the summer, with the monsoon season, I'm needing to brush every day. And when I do brush, it seems like my drain isn't sucking up the dust/dirt. Before brushing I switch my filter to drain only, and I turn the speed down to low rather than high, because I wasn't sure if the high speed would cause the dirt to float right past the drain.
Does this sound normal, to need to brush every day with an in-floor cleaner? I brush and, it seems to have helped, but later in the day the dirt is back. Did all my brushing only mix the dirt into the water and then it finally settled? Is my drain not working properly to suck it all up? I was thinking of getting a robotic cleaner to help out during the summer months. Any Arizonans have in-floor cleaners that could comment on whether or not it's normal to have to brush every day with an in-floor cleaner? Do you also have a robotic cleaner to supplement?
EDIT: We have a play pool 3 1/2 feet, 5 feet, 4 feet.
