Thread: Replacing Skimmer
    Replacing Skimmer
    Hey folks,
    Attached you'll see that I've just taken the concrete out from around my pool (18X36 In-Ground Vinyl). I now plan to replace all piping and the skimmer. I don't have a drain line.
    The piping is straight forward enough, however I don't know what to expect when it comes to the skimmer. Is this a DIY job for a DIY'er? Anything I should know about before I get into it? Is it self explanatory once I get going?
    Thanks!
    18 X 36 In-Ground Vinyl Pool, Hayward 1 HP SuperPump, Hayward SP270T 350lb Sand Filter, CompuPool CPSC48 Salt Chlorine Generator, Hayward H400FDN 400 BTU Natural Gas Heater, 2 returns, 1 skimmer, No Main Drain
    Guest
    Re: Replacing Skimmer
    Why do you want to replace it?
    Bruce
    Mainly because it's 30 years old. I know I've got suction side leaks. And it's probably my last easy opportunity for another 30 years.
