Finally, the tests are in!
pH - 7.5, CH - 75 to 100 (in between), FC - 1.5 ppm, CC - 2, TC - 3.5, TAC- 1.5, CYA - between 25 to 30 (more to closer to 30 is my guess). CYA test is very subjective. I tried like 5 times pouring the water back and forth. This is the best I can guess. Couldn't do the TA, but the pool store results from last night seem decent.
Pool store results from last night:
pH - 7.8 (Added some Muriatic acid to bring this down), CH - 90, FC - 2 ppm, TAC - 2, CYA - 40, TA - 90
I am getting ready to SLAM now as I want to get the pool ready for the weekend, if possible.
Based on the CYA chart, the shock FC needs to be around 12 ish?
Pool Math is telling me for a 27.5K gal pool, to raise the FC from 1.5 to 12 ppm, I need roughly 2.5-gallon jugs of 12.5% LC.
1. Do I dump them all in at once?
2. Measure every 2 hours?
3. Try to get some sleep in tossing/turning in between?
4. Clean the walls, filter sometime tomorrow before next dumping chlorine?
Onace again, Thanks for the help
Andy
Andy
