Pool Size Estimating Gallons
iain42
0
Oct 16, 2016
367
Little Rock AR
Our water bill came in today for the time period of the pool fill. We average 6CCF a month but this bill was 40CCF so that leaves us at 34CCF x 748 gallons = 25432 gallons. I thought we were closer to 18K. That is a big difference.
38' at the longest. 22' at the widest. 12' at the narrowest . Here are the measurements from this morning.
Does 25k seem reasonable? The odd shape does not make it easy to measure.
j6-PZV3dMVjb75OybjtbPtmtCfwBN5wXQTXcaJYaVROimbHK25lHGhUjOoXoowH72j2tJ71c-t070uCwbsc5uo6WNApg87KEK-NInuhK8fXeY3MHHNbGX7WNsPkgsRTvQJKr2Gr8OXwGufOKtFTryNuxUECN3qXNCDG6Dbd2zOcGyH0P6OMGLGlu9ZpfThnZ_TuU7WQ-n2y-pc31DuqqVtq6-EDBy-x3rpg8u_DHWF18nbaSVdi7QeulqJQ8zENy85sdZLfJibHpcVwMmafVlZN86v4OMGNRvooaA1yZghyCIIMcLg4KsEhaQodRMilBdNWJtXB-zeJHkdl5Y7z26w-7I7H_nIuwmWNsq__HhdR5iqUTv2eR4Hoj36pf18l4zNjUqEsibPDfYx831xX_khaRtuGu4397J0s9ICNPKdblwBgljZtbFDu7A23--hQSPdgXp1wu3vg7ROtj2sNoKNt0VdlzgHAQqWS_r3rHAsZJl2EIfzkmaSfBEmd5wcbCUFA8ETDobj91mEW6Nop9Jn7Me6C76uVPWY38Hc9JkobXF-Rlv2iwgM6iAsZ9FQ32v4j0HrfX-1jtaCRB15DPAunVwrVKIQSrJYx6JGrWTbu-ZKrdd6tIu1S13JQ_9d-kHLDDuCOAzuowp8ItAjizGNTF1wT_HolLDQ=w554-h288-no
Was your water meter reading the same month the pool was constructed? I guarantee that the construction crews used a lot of water.
I would guess about 15000 gallons. You can nail it down with muriatic acid or liquid chlorine and testing with a proper test kit.
They did use abit but there was quite the delay between gunite and filling the pool.
Is there a documented method for using chlorine or muratic acid for calculating gallons???
