I'm not sure if I have mustard or reg algae...it's mainly on walls in areas and along the tile line.
I plan on following the SLAM rules and will consult the CYA/FC chart. Will get pH at 7.2-7.3 before I start.
Ques's:
It says to run pump 7x24 first day..I have a VSP, what RPM's should it be run?
Also have another pump for scuppers: should I run that pump to periodically to circulate SLAM rated FC's? Also, should I run Spa lines too? this will take away from pool? Spa/Spillover and pool are connected so it's all circulating.
Finally, it's real overcast w no sun...will I get an accurate CYA test? Thoughts w no sun?
Thank you, tstex
Update on tests as of 10am CST
FC = 6
CC - there might have been a very, very slight color change to the lightest tint of pink, but it was not distinguished by any menas
TC= 6
CH= 225
TA = 60
CYA=45
pH=7.6
Based on CL/CYA Chart, I fall btw 40 CYA = 16 and 50 = 20, so an 18 is the FC SLAM..would going t0 20FC work?
I will first lower my pH to 7.2, then do the slam...Any help would be appreciated...thanks
Ques's:
Thank you, tstex
FC = 6
TC= 6
CH= 225
TA = 60
CYA=45
pH=7.6
