If I were to use a two stage pump, and figured on running that pump on low for 16 hrs instead of the normal 8, could I get by with a smaller sand filter, seeing as how the water would not be so vigorously be entering the sand filter. I saw a video where using the two stage pump on low 24 hrs a day was cheaper than the one speed pumps using only 8 hrs a day. Would a two stage 1hp pump and a 19" sand filter be a good size for an oval pool with 12000 gal.
