Results 1 to 8 of 8
Thread: using only half a solar blanket
    hi
    I was wondering if anyone is using only half a solar blanket, meaning covering only 50% of the pool.
    this will allow me to leave it on all the time. this makes it easier to handle if I need to remove, water is breathable, won't heat the water too much during the day, reduce evaporation. if only a 5 degrees is what I'm looking for, will this work. does this make any sense and is this a good compromise? my plan is to cover the deep end which is half the pool.
    thanks
    Jack
    CRG_80cc's Avatar
    Jul 2007
    Nor-Cal
    81
    Re: using only half a solar blanket
    If should be no problem. If it works for you, go for it.
    30K gal. IG Free form
    Cartridge Filter, Solar and Gas Heater
    Using BBB
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    505
    This is a great question! When we took our cover off today for a family gathering, the water was 92 degrees
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    seems like a choice between 8mils and 12mils.
    shipping seems pretty high but leslie's is overpriced.
    anyone with any good recommendations?
    I'm in san diego
    thanks
    Jack
    Jan 2009
    Cupertino, CA
    1,966
    You won't see as much benefit as with a full cover but I don't see that a half cover would do any harm. I'd recommend that the covered half not include the area right next to the skimmer; if you have any open water then the skimmer should get first crack at it. (My cover is about 90% and there's always crud in the open bit, which is nowhere near the skimmer.)
    8mil will be easier to take on and off but will die sooner. But with only a half cover probably the weight difference isn't so big a deal? A lot of people cut their covers into sections to make them easier to handle; you just aren't putting the other half on.
    --paulr
    BBB "Intermediate Swimmer"
    ok great.
    thanks!
    i just read in a few places that you shouldn't have the cover on long term and that if you have the cover on during the day, it would heat the water up too much.
    i live in a place where 95-100 degrees afternoon summers are common and very cool at night. lots of evaporation. i'm also on a mountain side with a nice breeze.
    i figure 50% coverage is a good compromise and will assist with slowing evaporation?
    CRG_80cc's Avatar
    Jul 2007
    Nor-Cal
    81
    Quote Originally Posted by jacksonlui
    I'm in san diego
    thanks
    Jack
    Jack
    Our local Lowe's carries solar covers, so give them a look. I have the Leslie's cover on mine and the price is about 25% higher this year compared to last year for the same one
    Using BBB
    Sep 2008
    The Woodlands, Texas, USA
    239
    We do this. Actually have it cut into 6 strips and much of fall and spring we do this. Works great. We ordered our cover from www. H2Opoolproducts.com
    good service.
    Good luck
    Lee
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
