Hi,
I also posted this over on the water chemistry part of the forum, but thought it probably should be here as well.
For those who have used this kit, does anyone have trouble determine the biguanide level? There is a very subtle color change that is supposed to take place when adding the Biguanide Titrating Reagent (color is supposed to change from light blue to pinkish purple). The first time I used the kit I was able to get a (hopefully) accurate reading, but in using it again today I couldn't get the color to change. I was up to as many as 30 drops of reagent with still no change - which is a bit ridiculous given that this amount of reagent would already indicate a level of at least 150. First test showed a reading of 15 (color changed at 3 drops) and then I brought the level up to the recommended 50 ppm.
In between the two tests, the only thing that changed is my having added 2 other products to the water: Ahhsome (designed to help with mold/slime issues) and Aqua Finesse Water Tablets. I'm wondering if in some way either of these products is interfering with and preventing me from getting a reading?
Thanks for any suggestions.....
