- May 23, 2015
- 24,487
- Plaster
- Pentair Intellichlor IC-60
The algaecide is going to be another quaternary amine compound (either PolyQuat-60 or a linear quat). Those will interfere with the titration test same as Ahh-some. So you’ll have to do your loss rate analysis without heavily using those algaecides.
Yes, the Aquafinesse has a lot of sodium carbonate in them. You should muriatic acid for lowering pH, dry acid is bad for plaster pools (because of sulfates attacking the plaster).
