Thread: Safe FCL to swim after shock?
    What is a safe FCL to swim in after shocking? I shocked around 30 ppm to kill off all the algae and want to know at what FCL level can we start swimming again? My daughter wants to jump back in the pool and we only have a few days of summer left. Thanks.
    Patriot Arcadia 15' round 52". Pentair Clean and Clear 100 sqft Cartridge filter, 1HP Optiflow pump, Goldline Aquatrol SWG. 2 - 4'x20' solar panels roof mounted. All rigid PVC plumbing. Resin Solar reel with 8mil Thermo-tex solar cover. 14 x 12 deck.
    Ovation 15'x24'x52'' AG. Pentair System 3 150 SQ foot cartridge filter, 1 1/2 HP pump.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: Safe FCL to swim after shock?
    Most on here think it's ok to swim at any level below shock level for your CYA
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, many of us think that anything between the minimum level and below shock level, based on your CYA, is perfectly fine.
    You're done SLAMing when:
    Hopefully we are below 21 ppm tonight so we can go swimming. Thanks.
    Jul 2009
    London and France
    574
    The EPA recommend no higher than 4ppm so take into account your CYA level and keep your childrens lungs safer.
    Mar 2007
    San Rafael, CA USA
    12,082
    The EPA recommendation is based on their drinking water standard which is 6-8 quarts consumed per day. Several states have 10 ppm FC as a limit for commercial/public pools. I'll write separately in The Deep End later on this week about a recent report on children's asthma and outdoor pools (a follow-on to an earlier study on indoor pools).
