Hi All,
After having trouble with my pool for a few years, I found this forum and decided to abandon the pool store for good. The results were almost immediate, and I went the remainder of last summer with no issues.
I opened the pool over the weekend hoping to find clear water, but unfortunately, that was not the case. I tested and below are my results:
FC: .8
CC: 2
pH: 7.0
Alk: 110
CYA: 0
Looks like my CYA disappeared over the winter. The reagent has an expiration date of 2019, and I am very cognizant about how I store the test kit, so I don't think it's an issue with the reagent.
Given the readings, I am aerating to get the pH up, as I am happy with my Alk. If there is an easier option, I am open to adding chemicals if need be.
My main question - can i SLAM with my CYA at 0, or do I need to get it up in the 20-30ppm range first? I don't want to start SLAM'ing and just wasting chlorine, so I have held off on doing anything. I plan on picking up some stabilizer after work today to start the process of getting the CYA up, but i also am worried that if i hold off too long on the SLAM process, the algae will just worsen.
thanks for the help!
FC: .8
CC: 2
pH: 7.0
Alk: 110
CYA: 0
