Hi all.
Just had my pool built last year. It’s 25k gallons, gunnite, with a quartz coating.
I quickly realized how annoying it is to drag the hose out to add water lost due to evaporation.
I have a sprinkler manifold pretty close to the equipment pad. The sprinkler system consists of 14 zones, mostly plumbed with black poly pipe, with some pvc. The main is 1”, with 3/4” lines to the heads. The system has a back flow valve at the main, as well as a master valve.
I know irrigation water is considered non-potable water, but so is pool water obviously. Would it be a bad idea to add another valve (zone), and plumb it to a return line and have it add water 10 minutes a day when the pump is not running?
I can add another backflow valve at the equipment pad as a preventative measure. I was even thinking of adding a JVA to my Aqualink and have it open only when the sprinkler system is filling the pool for further safety. So the system would be very well protected from backflow with multiple valves and fail safes.
What do do you guys think? I am located in New Jersey by the way.
Thanks all.
Thanks all.
