Lost my pool guy and doing this myself this year. Opened it this year and turned on the pump. The filter was leaking around the top. Bought new diaphragm gasket (genuine Hayward, but it is white instead of the original black if that matters). Bolts that hold the tube sheets together were rusted. Bought same size bolts and nuts (got phillips pan head instead of original that look like a hex head). Missing c-clip on bump shaft, bought new set and replaced the tiny o-rings on the shaft, washers and c-clip. Chem cleaned the fingers. Put it all back together and still leaking around the top. Few things I noticed:
1) New gasket didn't sit exactly inside the ridge it should. Maybe 1/4" out of it on one side. Meaning get it to sit right on one side, it moves out that 1/4" on the other side. Should I take the 16 bolts out of the tube sheet again and try to adjust there?
2) Because of this misfit on the gasket, one of the 15 screw holes for the top has the gasket 1/2 way covering the bolt hole. Do I definitely need to fix this or get out the darn drill and drill through the rubber? (Don't laugh, I'm desperate)
3) Possible that the problem is not gasket but the pan head bolts?
I usually have no problem with trial and error, but I'm sick of each trial requiring me to remove then replace 15 bolts on the outside and 16 bolts on the tube sheets, just to flip on the pump and flip it off again. Sigh. So if anyone has any words of wisdom I would greatly appreciate it. Gave up last night...about to go undo the 15 bolts AGAIN. If I don't get this running soon, I'm on the verge of a complete and total cesspool. Double sigh.
Thank you!
Thank you!
