new to the forums very frustrated. third year with the pool, last year pool not clearing but glass media in filter not working, switched to sand and worked well; this year pool hasn't been clear since opening; I have followed recommendations from 3 pool dealers 4 different times with no success; pool is creamy greenish blue color only able to see about 1 foot depth; FC levels are always at or near zero; I have balanced other chemicals and shocked at least 4 times with essentially zero change; I have drained 3 feet and replaced twice; I have a Taylor DPD test kit K-2005 that I am learning to use; pool dealer has checked filter and felt it was ok; any help or suggestions appreciated
so the water test from the above mentioned kit is:
FC 0
TC 1
CC 1
ph 7
TA 220
CH 340
CYA 80
started the slam and have checked at 1 and 3 hours. It seems water is turning green. Is that normal???
FC 0
TC 1
CC 1
ph 7
TA 220
CH 340
CYA 80
