I have my valves set so that for the two hours a day my pump runs, I get about 10% return flow through the spa. That seems to be enough water exchange to keep it clear. However, before I vacuum, I move the valves and pump the spa into the pool via the filter, and brush any debris at the spa drain. It's easier than trying to use the vacuum. Anyway, then while I'm vacuuming, I return it all to the spa. It minimizes the disturbance in the pool so I can see what I'm doing a little better, and it gives me pretty close to 100% water exchange in the spa once a week.
I have an air intake for some kind of venturi in the spa return jets. I capped that with a spray can lid to minimize aeration. Easy enough to get the bubbles back in the spa if I want 'em.
With my TA down at around 60, I pretty much only need to add acid when I add top off water every week or so.
