Aquavac P/N 36000QC Power Supply unit re-assembly question
mf7365
0
May 29, 2015
11
Sylvania/OH
I disassembled my power unit because the cord connection was loose and it has to be tightened with the plastic nut that is threaded on the inside of the unit. When I pulled apart the case the thin ribbon strip that connects the quick clean red light and full cycle button with yellow light to the electronic board came off before I could see which pins it connected to. There are 7 pins in a row on the board, but the connecting ribbon only has a 4 pin female connection. Anyone know which pins its supposed to go to?
Thanks. I just plugged the ribbon female end in randomly and put it back together and tried it today. It worked but the red quick clean light doesn't come on and pushing the button for the full cycle clean does nothing either as far as I can tell. The yellow light doesnt come at least. Could the ribbon being plugged into in the wrong pins be the culprit?
