First let me describe my pool/ spa and its set up.
My pool, Approx 19,000 gallons sits about 4 feet below my spa approx. 1000 gallons, The spa over fills and waterfalls back into the pool.
The plumbing:
The pump draws water from 3 possible locations: the Spa, the Skimmer/deep end drain, and the vacuum port. one valve selects between pool and spa and one valve selects between skimmer/drains and vaccum port.
The water then filters, goes through the Gas heater (rarely used only on when spa is in use) and solar heater and the swg, then returns to 2 pipes via a valve (Pool and spa) one leads to the spa jets, the other has a valve on its own that directs to the pool returns or to two additional water falls.
My concerns:
With my current single speed pump I draw from the pool only, half skimmer/drain half vaccum, and return half pool half spa with none of the 2 other water falls on unless we are using the pool.
The only way to filter/circulate the spa water is to return the clean water to it and let it over flow into the pool or shut off suction to the pool and only filter the spa water.
With a VS pump The water will trickle down the the stone work leading to algae and mold in all the crevices. It happens now (minor) but i assume it would be worse with hours of trickling water and i assume more efflorescence will occur as well. Unless i run the vs pump at a higher speed and operate it like my single speed so the water flows out like a waterfall.
Any thoughts or ideas?
The plumbing:
My concerns:
