I've had this pool for 10 years now and always just get it tested at the pool store and then buy their recommended chemicals. It's a 17,000 gallon plaster pool with spillover spa. We run a salt water chlorine generator. We are still hovering around 60-75F daytime highs so we won't turn the generator on until June.
I have the TF-100 test kit.
After removing the cover, is my first step to get the CYA between 70 and 80?
After that, I would refill until I get the water to skimmer level. At this point, should I SLAM the pool or start to vacuum to waste? We have a lot of trees and even with a cover, we get a lot of leaves in the pool over winter.
