Just joined the forum - found it while searching for ideas on a new pool build. Have met with several builders and made a selection. Finalizing paperwork next week. Details of the rough estimate are below - so anything you can point out we should reconsider, please let me know. Also, we are considering Corallock (or even Shellock) artistic pavers. See: Steplock Corallock Pavers for Pedestrian applications, Pool Pavers, Patios, Walkways - Artistic Paver Mfg. We do not have a big deck area and wanted something different than travertine. We are also going with salt water, and thought with the salt water (both in the pool and we are near intracoastal and ocean) we thought it would wear well. Any insight on its durability and maintenance would be great too! Thanks!!!
- Permit and engineered plans
- Small machine dig and haul
- 76 Lnft pool/10’ wide by 28’ long/3’ to 5’deep- up to 20 Lnft of steps, 2” or greater plumbing throughout pool
- 12” bond beam for placement of 16x16 coping
- Bench along shallow end wall with 2 therapy jets
- Steel reinforced high strength 6” thick gunite(concrete) wall
- Use of compactor and water to backfill around pool structure
- Swim-out bench with tiled edge in deep end of pool
- 3 directional returns
- Wide mouth skimmer with tiled throat
- Channel drain or dual main drains with required flow rates per Florida building code
- Dedicated vacuum line with adjustable valve and safety vacuum lock for automatic pool cleaner
- Automatic overflow line
- 16x16 square edge Corallock coping and standard 6” waterline tile
- 1 LED color light
- Hayward 1-1.65 HP MaxFlo VS Variable speed Energy efficient pump
- Hayward C150S filter
- Hayward Aquarite 25,000 gallon salt chlorination system
- Equipotential bonding wire per Florida building code
- 550 sqft of 16x16 Corallock concrete pavers(many sizes and color choices)
- Electrical hook-up-electrical panel with built in timer and breakers. Light switch in patio area.
- Standard Florida Stucco Florida Gem Quartz plaster finish
- Lifetime structural warranty on pool shell
- 10 year warranty on plaster
- 1 year warranty on pool
- 3 year warranty on Hayward equipment
- Brush, pole and net
- Initial chemical balance and pool instruction
