No steps in my pool just built in swim out in the deep end and steps and a lounge bench in the shallow end but all are part of the pool shell so there’s nothing to clean behind.
I have an auto fill that is currently unused (waiting on sprinkler system install after some other construction gets finished) but it is sealed off at the pool wall.
I do have a Pentair 300 chlorine dispenser thingy that has water in it currently but no chlorine pucks. I don’t think it’s for using liquid chlorine, only pucks. The pool company drained it over the winter and disconnected the lines so I’m not even sure I hooked it back up correctly. Does it matter or does the high pressure side just push the chlorinated water out the low pressure side regardless of how it’s hooked up? Could it be part of the problem?
I haven’t run the heater at all since opening but water flows thru the heater the way my plumbing is setup so I’m not sure if that could be a hiding spot but figured it’s sealed where the water runs through it.
The main drain cover cover has at most one small leaf on it at any given time. Do I need to swim down there and remove it or check inside with goggles on for a dead animal or something? I’m contemplating either calling my pool service company to just let them handle the chlorine and maintenance or using pucks if I have the feeder plumbed correctly to at least help maintain a minimal chlorine usage as I can’t keep dumping multiple gallons a day into the pool. I appreciate the replies.
