Our pool was built last year so clean water went in and I had no issues until the pool closed. Only needed to backwash once!
A few days ago we opened a murky mess. I didn't see everything that the pool company did, but when I arrived home the SWG had shutdown already through lack of flow and the filter seemed full so I did a backwash. I've messed up a couple of times already. I forget my filter was still on backwash while adding DE and when I switched back to filter, I fired DE directly into the pool. I also added about 20lbs salt to the skimmer basket which caused a "High Salt/Amps" error to appear until I realized to add it to the pool directly. The salt blocked the skimmer drain for a while, but it seems to have cleared because I sometimes see movement in the skimmer, more as the VSP increases power, sometimes none when the VSP is at 45% and the filter is "getting full". I've backwashed 2 or 3 times a day since then and the SWG always shuts down when my VSP is running at 45% through lack of flow.
The pool has been clearing. I recently tried using the pool vac to more directly dealing with the dirt but there were times I didn't see movement in the skimmers and the jets seemed to "burp".
Some questions:
Thanks!
Some questions:
- Have I permanently damaged anything by adding salt to the skimmer?
- Have I permanently damaged anything with the DE going in during the backwash?
- What do I do next? Will time just help stuff dissolve and things will sort themselves out?
Thanks!
