I've had this ongoing problem for a year or so, where I get a good bit of dirt and sand coming into the pool from the jets bringing in the water from the pump. I have 3 jets and two water features, with three pipes leading out from the pump -- one for each water feature, and one for all the jets. The closest jet spits out the most dirt out of the 3 jets, and each of the water features do quite a bit, as well.
If I vacuum the pool clean (with a robotic vacuum that has its own filter, i.e. no dirt goes back into the pump/filter), there will be plenty of new dirt in the pool within a couple of days. I tried turning off water features, and that didn't stop the dirt from coming in from the jets.
I can't figure out what is going on, and where this is coming from. The only common pipe where dirt could come in to reach all jets would be on the intake back to the pump, but then the filter would catch it, and there would be plenty of dirt in the filter when I clean it -- however, there isn't. The filter is usually dirty with bits of grass and whatnot.
The filter is a cartridge filter, so there's no sand in there.
The dirt is kind of redish brown, and I do have a bunch of that kind of dirt around the pool pump/filter. I also have some reddish brown rocks around the pool... but if there were disintegrating at this rate, they'd be gone by now -- I'm emptying out a ton of dirt every week.
Finally, there is no water loss, at least nothing obvious.
I'm really stumped... Any suggestions, ideas, or things I could try to test out theories?
