I took the cover off my pool the other day and the water seemed to look good, no algea just sediment on the bottom. I gave it a good brushing on the bottom and sides. I got the pump up and going and all was good, an hour later the filter was clogged and pressure was up about 10psi more than usual. I backwashed/rinsed and everything was all good again. I noticed about an hour later the same thing, clogged filter, higher pressure and very little flow from my return. I have now backwashed like this about 4 or 5 times and it keeps happening. I replaced my sand about 2 years ago. I did have a bad algae bloom last year at startup but had no issues rest of the summer, could my sand need to be replaced again due to that? Is there a cleaning method to the sand I might need to do? I've never had this issue in the 10 years I've had this pool except when there is a bad algae problem and it got clogged then. Like I said the pool was clear. This is a 24' above ground pool by the way
Jason
Jason
