Morning test results after the shock fiasco..
FC- 14
CC- 0
ph- 8.0 (acid demand was 15 drops)
TA- 90
CH- 330
CYA- 30
SI- 0.5
Notes; Pool water is clear, algae is not noticeable by the eye
Maintenance; cut the SWCG down 50%
Chemicals; based on the Acid Demand test, added 1gal of Muriatic Acid. Stopped with the conditioner.
Questions; I assume the 1 gal of Muriatic Acid is going to deteriorate my TA? Should I be adding baking soda, or should I just leave it alone and test again this evening?
Thanks in advance
FC- 14
CC- 0
TA- 90
CH- 330
CYA- 30
SI- 0.5
Thanks in advance
