When do you need to run a VS pump at other than low setting? I'd think if low setting moves enough GPM to turn your pool water over in a day, you wouldn't need high setting except maybe when vacuuming or running a water feature. But a local pool eqpt sales person told me a hayward VS should be run on low overnight, then on high 2 hours in the morning, then on medium during the day. He said it was to make sure you turn the water over in a day, but this just doesn't make sense to me if the GPM math says you can turn the water over just with low speed. What am i missing?
i am thinking about switching from a noisy old single speed to a VS. 30 year old gunite pool 27000 gallons, 1 1/2 inch pipe, sand filter 60 gpm capacity, chlorine tabs.
thanks!!
thanks!!
