Pressure gauge hasn't moved off 10 since I put the DE in it. I thought it be worse but it's not. I'm going to sweep tomorrow n then change the DE. The CCs are burning off right now. You can smell the pool before you see it. I added another gallon of 10% n will check it tonight before bed.
Phosphate remover....yeah, you should definitely add phosphate remover....
The DE should improve clarity fairly quickly (24-48 hours). Are you vacuuming through the filter now?
