Thread: de in my pool!
    de in my pool!
    Hi all!!
    Why is de getting into my pool? We bought a new hayward perflex filter because de was getting into the pool from day one. The new filter did not help. I ALWAYS have lots of de all over the bottom of the pool! Any ideas?
    (This is my first day on this site. What a hard time I had trying to figure out where to post a question!)
    Thanks!!
    18'x52, Hayward "The Missile filter
    Southern Wisconsin
    I use a chlorine floater and liquid chlorine as needed
    Constant algae problem
    Pool is under a large Elm, doesn't get sunlight all day
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: de in my pool!
    DE is a white/grayish powder.
    Dead algae is always a white/grayish powder.
    Maybe it's not DE?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Re: de in my pool!
    Thanks for responding Kevin! I don't think it is algae tho. Every single time I use the filter, it is in the pool. The water is crystal clear. I never have an algae problem. The amount of de in the pool couldn't possibly be algae.It is in there everyday. I vacuum it up and by the end of the day it is right back in there. It's making us nuts.
    I have to assume it isn't the filter, but somewhere between the filter and the pool.
    Thanks again!
    Southern Wisconsin
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: de in my pool!
    attempt to vacuum the pool on waste (basically bypass the filter) if it doesn't come back it's DE if it does come back then it is probably dead algae
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Re: de in my pool!
    One thing you can do to try to figure out what is going on is to put a nylon stocking over a return and see what accumulates in it. If anything is getting through the filter, it will show up in the stocking. But if the debris is coming from outside the pool it won't show up in the stocking.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: de in my pool!
    Welcome to TFP!!
    Have you bumped the new filter? If not, ignore this question.
    I can tell you how to break one down and check for the 'usual suspects' if it is DE and not algae or airborne debris
    Luv& Luk
    -Ted
