So hey it's me again,
we had an electrician here to quote us some work to get power near the pool instead of the pool to the power.
We have 2 more come to compare.
Anyway we have an "intex" type pool and he said even this one has to be bonded?
So I called our local pool store that sells/installs the "real" AGP and he said that even those don't require bonding.
So now I'm more than confused. Who will I need to contact to find out about correct code information?
And.... can a Intex even be grounded? Does it make sense to do so?
I mean I could wrap the copper wire around the legs and do it but does it make sense on that style of pool?
Also what about the pump? We have a grounding screw but nowhere did it say to do anything with it.
My pump just sits on a cinder block setup and that's it. Do i run some copper wire from the pump into the ground?
Any advice is appreciated
Thanks
Thanks
