Results 1 to 11 of 11
Thread: Acid and Chlorine Drums filled with water
    Mar 2018
    Sydney
    5
    I've got a Puresilk Chromatalyzer (like this one http://www.poolpower.com.au/images/CPS2_black.jpg), which automatically performs the tests and provides chlorine and acid from the drums when needed. I've however noticed that after a while, both drums were filled with pool water.
    I've been searching around and found that I might need to buy and install an injector valve (like this one Hayward / PureSilk Chromatalyzer One Way Check Valve - 33501TB by Hayward | PoolSpot) to prevent pool water from running into the drums. I'm however not sure how to install it though? Should I place it inside the drum?
    Any help is much appreciated. Thank you!
    AftonJeeper's Avatar
    May 2017
    Twin Cities, MN
    1,147
    Re: Acid and Chlorine Drums filled with water
    I'm not familiar with that device but it looks like the valve would thread into the drum and the hose would connect to the compression fitting (blue thing). The link you provided shows what I would call IV bags, do you have different containers?
    20'x48' 40,000 gal. Vinyl, Pentair Intelliflo 2 VST, Sta-Rite PLM300 System 2 Cartridge Filter, and a Pentair Mastertemp 250 heater all controlled by Pentair Easy Touch with Screen Logic. Dolphin Premier pool attendant.
    I've got iron stained well water. TF-100 and Speed Stir, Lamotte 3017-G for Borates
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,828
    A picture of how the drums are plumbed into the system would be helpful. I'm not sure if the valve you show would prevent backflow.
    Love TFP? Become a
    TFP Supporter!
    Mar 2018
    Sydney
    5
    Thank you for your replies! Below are some pictures of how the drums are connected to the system.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,541
    The peristaltic pumps should be holding the pool water back, but I'm just wondering if the drums are (maybe nearly a metre or several feet) below the pool water level?
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Tips for New Members to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mar 2018
    Sydney
    5
    Yes, the drums are about 2 feet under the pool water level. Thanks!
    needsajet's Avatar
    Jan 2016
    4,541
    It looks like you already have check valves on the injection points, but maybe you could order the other ones and see if they're any different.
    If they are already check valves, then I'm wondering if somehow it's allowing backflow through the peristaltic pumps when the system is off, or when the pressure is very low. If it was happening due to pressure in the return line, it would always be happening, and I think the tanks would be filling up pretty much right away.
    There are a few things I'd do. One is to put the drums at water level, maybe just up on a crate or chair temporarily and see if that stops the problem. The peristaltic pump should really be stopping the backflow, but maybe it's just a little too much pressure being that much below the waterline. Another is to set the acid tank a bit farther away to reduce the risk of any acid fumes causing corrosion on the expensive stuff. That might allow the acid tank and chlorine tank to be separated. It's normally good practice to store acid and chlorine in different places. The worst thing that could happen would be buying some to replenish one of the tanks and accidentally topping up the other tank. I know it's low risk, but the outcome is deadly, so for me it would be worthwhile reducing the possibility.
    Hopefully someone has experience with those valves and will know if either or both are effective check valves (one way valves).
    Seeing those two injectors on a branch made me wonder something. I'd hate to see it injecting chlorine and acid at the same time right next to each other. Does the system prevent that from happening, e.g. by only injecting acid or chlorine at any given time? I really wish those two injection points were direct into the return line so the liquid would get diluted right away.
    I think it's worth a call to Hayward to get their thoughts on what's going on. You're dealing with concentrated chlorine and acid, so it's well worth being sure.
    Mar 2018
    Sydney
    5
    Many thanks needsajet for such a detailed response. You've been very helpful! My response to the points you raised are below.
    Quote Originally Posted by needsajet View Post
    Yes, that what I was thinking too. The current valves on the injection points (as in the second picture) also have the arrows, which I think indicate one-way valves.
    The drums was filled up after a couple of weeks. I suspect that they are filling up only when the peristaltic pumps are running.
    Good idea! I'll do that.
    I've read the manual and it said that the system only injects acid or chlorine at any given time. The injection points are connected into the return line.
    Yes, I'll give them a call. Thank you again!
    needsajet's Avatar
    Jan 2016
    4,541
    Here's a crazy thought and this is really unlikely, but maybe worth ruling out. Make sure the pump is rotating the right direction. For example, if facing the pump, and the tubing coming from the drum is on the left, the pump should be rotating clockwise when injecting.
    Mar 2018
    Sydney
    5
    I've contacted the manufacturer and they said that it may be the time for annual service, meaning replacing the peristaltic pumps, tubes, valves, etc. .
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    2,595
    Acid & chlorine side by side under a window.
    When the service technician arrives ask him to move & separate the jugs please.
