Thread: Post Slam questions
    Sep 2017
    Conway, AR
    37
    Post Slam questions
    I recently completed a SLAM (8 days ago). My CYA before was 55 and now it appears to be about 25-30. What would make it drop that fast?
    My current parameters with a water temp of 56 degrees are :
    FC-17
    CC-0.0
    TA-85
    CH-360
    pH-7.2
    Obviously no swimming with these water temps but we do want to use the SPA. How low does the FC need to drop before thats ok?
    What temp do you turn your SWG back on?
    30K, plaster, heated SPA
    SWG Pentair Intellicholor IC40, pumps- Pentair Intelliflo 2VST X2 (1 for main filtration 1 for water features)
    Pentair remote control, Pentair natural gas heater
    4x four foot canister filters
    Jan 2012
    'burbs of Augusta, Georgia
    8,855
    Re: Post Slam questions
    It is safe to swim up to SLAM levels of FC.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    31,199
    There is NO reason for your CYA to drop like that unless you have diluted your pool by draining and adding new water.
    There is a testing error somewhere.......a SLAM has no significant affect on CYA
    Sep 2017
    Conway, AR
    37
    That was my first thought. We did have almost 15" of rain over the last 2-3 weeks requiring me to drain the pool 3 times. That is probably the reason as it did dilute everything else as well. I had concentrated on restoring Alk/Ca/FC due to the low temps. I'll get on the CYA replacement.
