Thread: Pool Heater is no longer a feasible option for me, would a solar cover help much?
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    I posted something on here at the end of last season asking about a pool heater and got some good advice and the estimates given on here were pretty close. My biggest problem is that the gas line as far as it could possibly be from my pool plumbing. The estimates to run the gas line are way more than the cost and installation of the heater itself.
    Given the fact that the only reason i was looking into this in the first place was to extend my pool season, I'm all but abandoning the pool heater option because it's not worth it. I think i'll take that money and have some of big shade trees trimmed or taken out and look into a solar cover.
    So what's the difference between a solar cover and a regular old black plastic cover that I have on my pool right now? I'm reading that the main thing a solar cover does is slow evaporation. Wouldn't my regular cover do that?
    This is my first year of covering the pool in the off season, can I expect the temperature to be higher this year after leaving a cover on it all spring?
    Memphis, TN.
    Pool IG, 20K gallon, Gunite. Triton Sand filter, Pentair Pump, Polaris 280, Doheny Discovery Dolphin, Chlorinating Liquid, Rock Water Feature, New Plaster 2015
    Spa 450 gal, Tropic Seas Waikiki 864L, Bromine
    Taylor K-2006
    Jan 2012
    'burbs of Augusta, Georgia
    8,864
    Re: Pool Heater is no longer a feasible option for me, would a solar cover help much?
    BigDog, have you considered a heat pump?
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Yes, that was what I was originally thinking. But folks on here and the pool company's I've consulted with are singing the same song. That a heat pump probably won't work as well as I want it to and it will take a tremendous amount of time to move the needle on my pool temp.
    Honestly though, I think that might be ok. I'm not looking for it to heat up overnight.
    Memphis, TN.
    Taylor K-2006
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,479
    I think that a heat pump used in combination with a solar cover will get you what you need. A heat pump heats low and slow but once you get to the temp you want it will be pennies to maintain it, however you must cover the pool with a bubble solar cover so you do not loose the heat you gained from evaporation at night.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
