- Jun 7, 2017
- 9,124
- Plaster
- Jandy Aquapure 1400
I realized the other day when doing some winter maintenance that my umbrella sleeves never got glued in. They just pull out. Can I glue these while they are under around 4" of water? The pool is winterized so the water level has been reduced by around a foot. I can pump some more water out to get them dry as they are almost out of the water now but probably would mean pumping several thousand gallons out. I'd prefer not to if the PVC glue will work underwater. I'd remove the sleeves, slather on PVC glue, then put them back and hold them down with a rock until cured.
