Thread: Worried about my PH Level
    Keller, TX
    19
    Ok have an algae problem and I read the post on how to take care of it. I went out and bought a whole bunch of bleach and some dry acid. I lowerd my ph to about 7.4 before adding the bleach to get it to shock level. I put 3 gallons of bleach in which is what it said would get me to a fc level of 15. I checked in 30 min and I screwed up the test. It kept saying I didn't have any chlorine in the pool so I kept adding bleach. After adding 9 gallons of bleach I realized I was forgetting to add the second set of drops for the chlorine test. Now that I am testing it right the chlorine is pretty high. (My reader only goes to an fc of 5 so I diluted it 1 part pool water 3 parts purified water and it is still darker than 5 so I know my fc is above 20) The problem is that my PH level is now above 8.2. Is this because I have put so much bleach in. Do I need to put more ph reducer in before I add any more bleach?
    FC - 20+
    pH - 8.2
    TA - 140
    CYA - 40
    Our pool is 12,481 gallons
    The pump has a cartrige type filter
    It's an AG pool
    Pump is an Intex 633 2500 gph
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Worried about my PH Level
    What chlorine test are you using? Can you detail how you are doing it?
    Ph reads falsely high when the chlorine is over 10ppm.
    Keller, TX
    19
    I'm using Leslie's Total Pool Care DPD test kit. I use 5 drop of R-001 and 5 drops of R-002 but it reads too high because my reader only goes as high as 5 for FC. That is why I diluted it with purified water. The reason I was messing up is because I kept forgetting to put the 5 drops of R-002 in the tester so I kept thinking there was no chlorine. But if you say the ph level reads falsly high when the fc is over 10 ppm then I should be ok. I will keep monitoring the fc every half hour to keep the level at shock level until the pool starts to clear. Hopefully it will start to work. This has been a real pain.
    It's an AG pool
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
