So with a variable speed pump how does someone find the right values? Basically how long to run it and at what speed??
i guess i need 3 different settings, regular daily cleaning, water features (bubbler and 2 deck jets) and heating (heat pump)
For water features only me can tell what the right speed is, and the time... so forget about that one....
For the heater i read that you should start really slow and add 50/100 rpm ultil the heater goes from no flow to flow, and add 100 to do that... is this the way?
And for daily run a similar aproach as the heater just set it really slow and go up 50/100 rpm at the time until my salt system detects flow? Is this correct?? if so then what is the correct time? How long per day?
