Thread: Pool side basketball hoops
    dmcody's Avatar
    Jun 2008
    Pittsburgh, PA
    78
    Looking for advice on a basketball hoop for our pool. Kids have been asking for a hoop and Iíd prefer a permanently installed version, but I didnít plan on this when I built the pool. Our coping is 24Ē wide x ~5Ē deep concrete and then pavers behind it as shown in this picture.
    Knowing that teenage boys would most likely hang on the rim, Iím not sure if I should get a permanently installed hoop or one with a heavy water filled base. I would appreciate any thoughts/experiences.
    Does anybody have experience with this basketball hoop I found on amazon? The base claims to be 500 lbs when filled with water.
    https://www.amazon.com/Dunnrite-Spla...Z6DRY2VSJPN9BR
    Pool Type/Size: Inground Vinyl ~24,000 gal ~ 18' x 36'
    Filter Type: Pentair FNS Plus 36 - DE Filter
    Pump: Pentair Challenger - 1.5 hp
    Heater: Pentair Mastertemp 250K BTU
    Accessories: Hayward AquaRite SWG Controller
    AftonJeeper's Avatar
    May 2017
    Twin Cities, MN
    1,147
    Re: Pool side basketball hoops
    Ours was installed when the pool was built. If you go with a permanently installed one you will have to pull up some pavers and pour a new footing along with bonding the base to the rest of the pool.
    The one you linked to looks very nice and that is probably what I would do in your situation.
    20'x48' 40,000 gal. Vinyl, Pentair Intelliflo 2 VST, Sta-Rite PLM300 System 2 Cartridge Filter, and a Pentair Mastertemp 250 heater all controlled by Pentair Easy Touch with Screen Logic. Dolphin Premier pool attendant.
    I've got iron stained well water. TF-100 and Speed Stir, Lamotte 3017-G for Borates
    dmcody's Avatar
    Jun 2008
    Pittsburgh, PA
    78
    That was my thought as well. Its just too much work for a few years of use. Thanks
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,232
    Yes, I highly recommend that one. I have it. It's awesome. You can see some pics of it in action in my build thread, but here's one too.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    dmcody's Avatar
    Jun 2008
    Pittsburgh, PA
    78
    Thanks. We pulled the trigger this weekend and it should be here in a week or so. Now I just need warm weather to arrive so I can open the pool.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,232
    Yeah, once the snow threat stops I suppose.
