HEY folks need some advice from you guys. Moved from AZ to Florida last year and bought a used house, a very used house. After having to unexpectedly replace all of the appliances we are finally ready to tackle the pool. It has been running but poorly. Single speed 1 1/2 HP Hayward pump, a leaking CX1200RE cartridge filter, Pentair single color light powered by a rusted through massive transformer box, Intermatic timer, and an Aquatherm Heat Pump that has recently blown a PCB. I want to rip it all out and put in mid grade stuff because we might end up selling the house and building new.
I have picked out the following equipment and want to know if I am somewhat on track or way off base.
Hayward: SP15932S PowerFlow Matrix 2 speed 115V 1.5HP 297.49
CX1200RE filter 379.99
Prologic Controller 685.44
Salt Cell T9 369.99
HP21004T Heat Pump 2599.99
Pentair: Intellibrite multicolor light 500.00
Pool is approximately 13000 gallons with a tiny water fall 2 foot tall by 2 foot wide and it has air jets around the pool above the bench seats in the pool. These are variable flow and can be adjusted on or off.
ANNNND if this wasn't enough...lol we also have a huge separate water feature with a second pump and pool filter. I'll create a different thread for that one because I think it is plumbed wrong and that will be the next project. Only reaon why I mention it is because i want to also control that pump with the pool controller. This pump will be a single speed no frills as when turned on it just needs to flow. Also this feature may also have fish in it if we can make that work.
Let me know what other info you guys may need.
Thanks in advance.
Salt Cell T9 369.99
Thanks in advance.
